Subtyping constraints in quasi-lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Emmanuel Coquery
Francois Fages
In this report, we show the decidability and NP-completeness of the satisfiability problem for non-structural subtyping constraints in quasi-lattices. This problem, first introduced by Smolka in 1989, is important for the typing of logic and functional languages. The decidability result is obtained by generalizing Trifonov and Smith's algorithm over lattices, to the case of quasi-lattices. Similarly, we extend Pottier's algorithm for computing explicit solutions to the case of quasi-lattices. Finally we evoke some applications of these results to type inference in constraint logic programming and functional programming languages.
Autre [cs.OH]
RR-4926.pdf (196.13 Ko) Télécharger le fichier
inria-00071653 , version 1 (23-05-2006)
  • HAL Id : inria-00071653 , version 1
Emmanuel Coquery, Francois Fages. Subtyping constraints in quasi-lattices. [Research Report] RR-4926, INRIA. 2003. ⟨inria-00071653⟩
88 Consultations
183 Téléchargements
