Calculating tau-Confluence Compositionally - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Frédéric Lang
Radu Mateescu
  • Fonction : Auteur
tau-confluence is a reduction technique used in explicit state model-checking of labeled transition systems to avoid the state explosion problem. In this report, we propose a new on-the-fly algorithm to calculate partial tau-confluence, and propose new techniques to do so on large systems in a compositional manner. Using information inherent in the way a large system is composed of smaller systems, we show how we can deduce partial tau-confluence in a computationally cheap manner. Finally, these techniques are applied to a number of case studies, including the rel/REL atomic multicast protocol.
RR-4918.pdf (251.22 Ko) Télécharger le fichier
inria-00071661 , version 1 (23-05-2006)
  • HAL Id : inria-00071661 , version 1
Gordon Pace, Frédéric Lang, Radu Mateescu. Calculating tau-Confluence Compositionally. RR-4918, INRIA. 2003. ⟨inria-00071661⟩
117 Consultations
135 Téléchargements
