What is the Search Space for the Inference of Non Deterministic, Unambiguous and Deterministic Automata ? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
A classical problem in inferring automata from data is to find the smallest compatible automaton, i.e. the smallest automaton accepting all examples and rejecting all counter-examples. We are interested in Non-deterministic Finite Automata (NFA) inference which is better suited to Occam's razor optimization principle than Deterministic Finite Automata (DFA). We revisit the existing results on the search space in the state-merging framework, focusing on nondeterminism. We introduce unambiguous automata (UFA) inference, an intermediate between the difficult NFA inference framework and the weaker DFA inference framework. The UFA search space, though containing nondeterministic automata, shares many properties with the DFA search space. Our conclusion is that the search spaces of UFA and DFA are lattices when using adequate operators.
RR-4907.pdf (475.18 Ko) Télécharger le fichier
inria-00071673 , version 1 (23-05-2006)
  • HAL Id : inria-00071673 , version 1
François Coste, Daniel Fredouille. What is the Search Space for the Inference of Non Deterministic, Unambiguous and Deterministic Automata ?. [Research Report] RR-4907, INRIA. 2003. ⟨inria-00071673⟩
136 Consultations
49 Téléchargements
