Influence of an Interface Condition and Exact Linearization in the Newton Iterations for Two-Phase Flow in Heterogeneous Porous Media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Block heterogeneities have an important influence on macroscale multiphase fluid flow and transport in porous media. We focus especially on the interface between different materials and linearization schemes in order to improve the efficiency of the numerical simulator.
RR-4903.pdf (1.49 Mo) Télécharger le fichier
inria-00071680 , version 1 (23-05-2006)
  • HAL Id : inria-00071680 , version 1
Jennifer Niessner, Jean Roberts, Rainer Helmig. Influence of an Interface Condition and Exact Linearization in the Newton Iterations for Two-Phase Flow in Heterogeneous Porous Media. [Research Report] RR-4903, INRIA. 2003. ⟨inria-00071680⟩
84 Consultations
206 Téléchargements
