inria-00071715, version 1
Approximation of the second fundamental form of a hypersurface of a Riemannian manifold
David Cohen-Steiner
1Jean-Marie Morvan
N° RR-4868 (2003)
Résumé : We give a general Riemannian framework to the study of approximation of curvature measures, using the theory of the normal cycle. Moreover, we introduce a differential form which allows to define a new type of curvature measure encoding the second fundamental form of a hypersurface, and to extend this notion to geometric compact subsets of a Riemannian manifold . Finally, if a geometric compact subset is close to a smooth hypersurface of a Riemannian manifold, we compare their second fundamental form (in the previous sense), and give a bound of their difference in terms of geometric invariants and the mass of the involved normal cycles.
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Autre
- Mots-clés : NORMAL CYCLE / APPROXIMATION / RIEMANNIAN MANIFOLD / CURVATURE / SECOND FUNDAMENTAL FORM
- Référence interne : RR-4868
- inria-00071715, version 1
- http://hal.inria.fr/inria-00071715
- oai:hal.inria.fr:inria-00071715
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mardi 23 Mai 2006, 18:35:38
- Dernière modification le : Mercredi 31 Mai 2006, 14:24:25
Documents associés
Exporter
