Refinement and Verification of Synchronized Component-based Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
This article deals with specification, refinement and verification approaches for systems designed with synchronized components. First of all, we define a synchronized composition of components. Transition systems are used to specify or/and to model synchronized component-based systems. Second, we give refinement semantics for these component-based systems before proposing a method to verify the refinement of a whole system from the weak refinement of its components. We also present SynCo (for Synchronized Component-based Systems): a tool we are implementing using our method. Third, a compositional way to verify safety properties is proposed: the unreachability of a (set of) state(s) can be efficiently ensured for a synchronized component-based system. The different aspects of our work are illustrated on an industrial example of a wind-screen wipers system composed of a control lever, a rain sensor and two (left and right) wind-screen wipers.
RR-4862.pdf (536.57 Ko) Télécharger le fichier
inria-00071721 , version 1 (23-05-2006)
  • HAL Id : inria-00071721 , version 1
Olga Kouchnarenko, Arnaud Lanoix. Refinement and Verification of Synchronized Component-based Systems. [Research Report] RR-4862, INRIA. 2003, pp.29. ⟨inria-00071721⟩
123 Consultations
277 Téléchargements
