Global abstraction-safe marshalling with hash types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Type abstraction is a key feature of ML-like languages for writing large programs. Marshalling is necessary for writing distributed programs, exchanging values via network byte-streams or persistent stores. In this report we combine the two, developing compile-time and run-time semantics for marshalling, that guarantee abstraction-safety between separately-built programs. We obtain a namespace for abstract types that is global, i.e. meaningful between programs, by hashing module declarations. We examine the scenarios in which values of abstract types are communicated from one program to another, and ensure, by constructing hashes appropriately, that the dynamic and static notions of type equality mirror each other. We use singleton kinds to express abstraction in the static semantics; abstraction is tracked in the dynamic semantics by coloured brackets. These allow us to prove preservation, erasure, and coincidence results. We argue that our proposal is a good basis for extensions to existing ML-like languages, pragmatically straightforward for language users and for implementors.
RR-4851.pdf (714.66 Ko) Télécharger le fichier
inria-00071732 , version 1 (23-05-2006)
  • HAL Id : inria-00071732 , version 1
James J. Leifer, Gilles Peskine, Peter Sewell, Keith Wansbrough. Global abstraction-safe marshalling with hash types. [Research Report] RR-4851, INRIA. 2003. ⟨inria-00071732⟩
83 Consultations
228 Téléchargements
