Modeling Fractures and Barriers as Interfaces for Flow in Porous Media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We consider a fractured porous medium that is studied at a scale such that the fractures can be modeled individually. Models for flow in which the fractures are interfaces between subdomains are presented. These models take into account interactions between the fractures and the surrounding porous medium. Existence and uniqueness of the solution to the model problem is proved. Error estimates show convergence as O(max(h,d)) in the L2 norm, where h is the mesh size and d the fracture width. Numerical experiments confirm the theorical results.
Autre [cs.OH]
RR-4848.pdf (1018.78 Ko) Télécharger le fichier
inria-00071735 , version 1 (23-05-2006)
  • HAL Id : inria-00071735 , version 1
Jérôme Jaffré, Vincent Martin, Jean Roberts. Modeling Fractures and Barriers as Interfaces for Flow in Porous Media. [Research Report] RR-4848, INRIA. 2003. ⟨inria-00071735⟩
249 Consultations
660 Téléchargements
