A Volumetric Reconstruction Method from Multiple Calibrated Views using Global Graph Cut Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
In this paper, a new formulation and solution to volumetric reconstruction from multiple calibrated images is presented. This problem has been previously formulated either as a continuous geometric optimization process driven by local numerical methods, or as a discrete labelling problem solved by global techniques for computing only stereo disparities. Our new formulation builds a bridge between these two approaches and takes advantage of both: a continuous geometric functional is minimized up to a discretization by a global graph cut algorithm. The relation between the continuous and discrete formulations is straightforwardly established. The minimization operates on a 3D embedded graph whose minimal cut is a solution of the discrete problem, leading to a global minimum. This new approach handling both occlusions and discontinuities has been demonstrated on real sequences, giving remarkably detailed surface geometry up to 1/10th pixel.
RR-4843.pdf (569.15 Ko) Télécharger le fichier
Format : Figure, Image
inria-00071742 , version 1 (23-05-2006)
  • HAL Id : inria-00071742 , version 1
Sylvain Paris, François X. Sillion, Long Quan. A Volumetric Reconstruction Method from Multiple Calibrated Views using Global Graph Cut Optimization. [Research Report] RR-4843, INRIA. 2003. ⟨inria-00071742⟩
127 Consultations
208 Téléchargements
