Multiple Precision Interval Packages:Comparing Different Approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
M. Grimmer
  • Fonction : Auteur
K. Petras
  • Fonction : Auteur
Nathalie Revol
We give a survey on packages for multiple precision interval arithmetic, with the main focus on three specific packages. One is within a Maple environment, intpakX, and two are C/C++ libraries, GMP-XSC and MPFI. We discuss their different features, present timing results and show several applications from various fields, where high precision intervals are fundamental.
Autre [cs.OH]
RR-4841.pdf (677.92 Ko) Télécharger le fichier
inria-00071744 , version 1 (23-05-2006)
  • HAL Id : inria-00071744 , version 1
M. Grimmer, K. Petras, Nathalie Revol. Multiple Precision Interval Packages:Comparing Different Approaches. RR-4841, INRIA. 2003. ⟨inria-00071744⟩
60 Consultations
274 Téléchargements
