Multiplication-addition modulaire: algorithmes itératifs et implantations sur FPGA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
This paper describes several improvements of an iterative algorithm for modular multiplication originally proposed by Jeong and Burleson. A first modification of the recurrence relation allows us to implement a fused multiply and add unit. Then, we show how to reduce the circuit area by a factor two when the operator offers the possibility to choose the modulo among a set m_1, m_2,, m_q. A new iterative algorithm making the implementation of modular exponentiation easier is eventually discussed. For 16-bit numbers, our operators perform for instance 6 millions of operations per second on a Virtex-E device while only requiring 17 slices.
Autre [cs.OH]
RR-4840.pdf (220.77 Ko) Télécharger le fichier
inria-00071745 , version 1 (23-05-2006)
  • HAL Id : inria-00071745 , version 1
Jean-Luc Beuchat. Multiplication-addition modulaire: algorithmes itératifs et implantations sur FPGA. RR-4840, INRIA. 2003. ⟨inria-00071745⟩
74 Consultations
947 Téléchargements
