Counting points in medium characteristic using Kedlaya's algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Recently, many new results have been found concerning algorithms for counting points on curves over finite fields of characteristic p, mostly due to the use of p-adic liftings. The complexity of these new methods is exponential in p therefore they behave well when p is small, the ideal case being p=2. When applicable, these new methods are usually faster than those based on SEA algorithms, and are more easily extended to non-elliptic curves. We investigate more precisely this dependance on the characteristic, and in particular, we show that after a few modifications using fast algorithms for radix-conversion, Kedlaya's algorithm works in time almost linear in p. As a consequence, this algorithm can also be applied to medium values of p. We give an example of a cryptographic size genus 3 hyperelliptic curve over a finite field of characteristic 251.
Autre [cs.OH]
RR-4838.pdf (305.54 Ko) Télécharger le fichier
inria-00071747 , version 1 (23-05-2006)
  • HAL Id : inria-00071747 , version 1
Pierrick Gaudry, Nicolas Gürel. Counting points in medium characteristic using Kedlaya's algorithm. [Research Report] RR-4838, INRIA. 2003. ⟨inria-00071747⟩
95 Consultations
262 Téléchargements
