A novel family of geometrical transformations: Polyrigid transformations. Application to the registration of histological slices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Vincent Arsigny
  • Fonction : Auteur
  • PersonId : 833435
Xavier Pennec
We present in this report a novel kind of geometrical transformations, which we have named polyrigid. Within their framework, it is possible to define local rigid deformations in a given number of simple regions, while simultanously guaranteeing the smoothness and invertibility of the global transformation. Entirely parametric, this new type of tool is highly suitable for inference, and it is successfully applied to the non-rigid registration of histological slices. These general transformations are a nice alternative to classical B-Spline transformations (which do not guaranty invertibility). In future work, other applications will be considered, for instance in 3D registration.
RR-4837.pdf (1.28 Mo) Télécharger le fichier
inria-00071748 , version 1 (23-05-2006)
  • HAL Id : inria-00071748 , version 1
Vincent Arsigny, Xavier Pennec. A novel family of geometrical transformations: Polyrigid transformations. Application to the registration of histological slices. RR-4837, INRIA. 2003. ⟨inria-00071748⟩
87 Consultations
102 Téléchargements
