Modular system development with pullbacks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Two, seemingly different modular techniques for concurrent system development are investigated from a categorical perspective. A novel approach is presented in which they turn out to be merely special instances of pullback, a general categorical limit construction. Interestingly, the approach is based on truly concurrent semantics of systems.
RR-4828.pdf (289.36 Ko) Télécharger le fichier
inria-00071758 , version 1 (23-05-2006)
  • HAL Id : inria-00071758 , version 1
Marek Bednarczyk, Luca Bernardinello, Benoit Caillaud, Wieslaw Pawlowski, Lucia Pomello. Modular system development with pullbacks. [Research Report] RR-4828, INRIA. 2003. ⟨inria-00071758⟩
146 Consultations
253 Téléchargements
