Image Denoising using Stochastic Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Xavier Descombes
Elena Zhizhina
  • Fonction : Auteur
We address the problem of image denoising using a Stochastic Differential Equation approach. We consider a diffusion process which converges to a Gibbs measure. The Hamiltonian of the Gibbs measure embeds an interaction term, providing smoothing properties, and a data term. We study two discrete approximations of the Langevin dynamics associated with this diffusion process: the Euler and the Explicit Strong Taylor approximations. We compare the convergence speed of the associated algorithms and the Metropolis-Hasting algorithm. Results are shown on synthetic and real data. They show that the proposed approach provides better results when considering a small number of iterations.
RR-4814.pdf (1.05 Mo) Télécharger le fichier
inria-00071772 , version 1 (23-05-2006)
  • HAL Id : inria-00071772 , version 1
Xavier Descombes, Elena Zhizhina. Image Denoising using Stochastic Differential Equations. RR-4814, INRIA. 2003. ⟨inria-00071772⟩
167 Consultations
504 Téléchargements
