s'authentifier
version française rss feed
inria-00071778, version 1
Anisotropic Polygonal Remeshing
Pierre Alliez () a1, David Cohen-Steiner () 1, Olivier Devillers () a1, Bruno Lévy a2, Mathieu Desbrun b3
N° RR-4808 (2003)
Résumé : In this paper, we propose a novel polygonal remeshing technique that exploits a key aspect of surfaces: the intrinsic of natural or man-made geometry. In particular, we use curvature directions to drive the remeshing process, mimicking the lines that artists themselves would use when creating 3D models from scratch. After extracting and smoothing the curvature tensor field of an input geometry patch, lines of minimum and maximum curvatures are used to determine appropriate edges for the remeshed version in anisotropic regions, while spherical regions are simply point-sampled since there is no natural direction of symmetry locally. As a result our technique generates polygon meshes mainly composed of quads in anisotropic regions, and of triangles in spherical regions. Our approach provides the flexibility to produce meshes ranging from isotropic to anisotropic, from coarse to dense, and from uniform to curvature adapted.
  • Domaine : Informatique/Autre
  • Mots-clés : SURFACE REMESHING / ANISOTROPIC SAMPLING / POLYGON MESHES / LINES OF CURVATURES / TENSOR FIELDS / APPROXIMATION THEORY
  • Référence interne : RR-4808
  • inria-00071778, version 1
  • oai:hal.inria.fr:inria-00071778
  • Contributeur :
  • Soumis le : Mardi 23 Mai 2006, 18:45:34
  • Dernière modification le : Mercredi 5 Novembre 2008, 16:34:05
tous les articles de la base du CCSd...
