inria-00071791, version 1
Performance Analysis of Remote File System Access over High Bandwidth Local Network
Brice Goglin
1, 2Loïc Prylli 1, 2
Workshop on Communication Architecture for Clusters (CAC'04), held in conjunction with the 18th IEEE IPDPS Conference (2004)
Résumé : We study the performance of file servers, comparing NFS implementation in Linux to our experimental lightweight system called ORFA. The aim is to find out NFS bottlenecks in the case of high bandwidth local network. Using a simple protocol without cache allow us to get best performance from the underlying communication subsystem. Our user-level implementation avoids several kernel-level constraints and thus provides better performance than NFS. Moreover we explore several optimization techniques to reduce the server overhead which usually is the bottleneck.
- 1 : RESO (INRIA Rhône-Alpes)
- INRIA – CNRS : UMR5668 – École Normale Supérieure - Lyon
- 2 : Laboratoire de l'Informatique du Parallélisme (LIP)
- Université de Lyon – CNRS : UMR5668 – INRIA – École Normale Supérieure - Lyon – Université Claude Bernard - Lyon I
- Domaine : Informatique/Autre
- Mots-clés : DISTRIBUTED FILE SYSTEM / REMOTE ACCESS / HIGH BANDWIDTH LOCAL NETWORK / CLUSTER / LINUX / NFS
- Référence interne : RR-4795
- inria-00071791, version 1
- http://hal.inria.fr/inria-00071791
- oai:hal.inria.fr:inria-00071791
- Contributeur : Brice Goglin
- Soumis le : Mardi 23 Mai 2006, 18:47:04
- Dernière modification le : Lundi 14 Juin 2010, 09:54:18
Documents associés
Exporter
