Some results on the controllability of planar variational inequalities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
This note deals with the controllability of a class of planar complementarity dynamical systems, which can also be viewed as planar variational inequalities. It is shown that the complementarity conditions influence a lot the controllability of the system.
RR-4788.pdf (259.93 Ko) Télécharger le fichier
inria-00071798 , version 1 (23-05-2006)
  • HAL Id : inria-00071798 , version 1
Bernard Brogliato. Some results on the controllability of planar variational inequalities. RR-4788, INRIA. 2003. ⟨inria-00071798⟩
63 Consultations
163 Téléchargements
