Geometry and Numerics of CMC Surfaces with Radial Metrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Thsi paper investigates the geometry of non-zero constant mean curvature surfaces with radial metric, putting an emphasis on the link between the Hopf differential and the extrinsic geometry. New asymptotic estimations of the metrics are given at the umbilical point and at infinity. The last section proposes an algorithm for numerical constructions.
RR-4763.pdf (652.09 Ko) Télécharger le fichier
inria-00071823 , version 1 (23-05-2006)
  • HAL Id : inria-00071823 , version 1
Gabriel dos Reis. Geometry and Numerics of CMC Surfaces with Radial Metrics. RR-4763, INRIA. 2003. ⟨inria-00071823⟩
71 Consultations
187 Téléchargements
