Linear programming problems for frontier estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We propose new estimates for the frontier of a set of points. They are defined as kernel estimates covering all the points and whose associated support is of smallest surface. The estimates are written as linear combinatio- ns of kernel functions applied to the points of the sample. The coefficients of the linear combination are then computed by solving a linear programming problem. In the general case, the solution of the optimizat- ion problem is sparse, that is, only a few coefficients are non zero. The corresponding points play the role of support vectors in the statistical learning theory. The L_1 error between the estimated and the true frontiers is shown to be almost surely converging to zero, and the rate of convergence is provided. The behaviour of the estimates on finite sample situations is illustrated on some simulations.
Autre [cs.OH]
RR-4717.pdf (313.65 Ko) Télécharger le fichier
inria-00071869 , version 1 (23-05-2006)
  • HAL Id : inria-00071869 , version 1
Guillaume Bouchard, Stéphane Girard, Anatoli B. Juditsky, Alexander Nazin. Linear programming problems for frontier estimation. [Research Report] RR-4717, INRIA. 2003. ⟨inria-00071869⟩
87 Consultations
109 Téléchargements
