Fast Forwarding with Network Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
E. Lemoine
  • Fonction : Auteur
Cong-Duc Pham
B. Tourancheau
Forwarding is a mechanism found in many network operations. Although a regular workstation is able to perform forwarding operations it still suffers from poor performances when compared to dedicated hardware machines. In this paper we study the possibility of using Network Processors (NPs) to improve the capability of regular workstations to forward data. We present a simple model and an experimental study demonstrating that even though NPs are less powerful than Host Processors (HPs) they can forward data more efficiently than HPs in some specific cases.
Autre [cs.OH]
RR-4710.pdf (250 Ko) Télécharger le fichier
inria-00071876 , version 1 (23-05-2006)
  • HAL Id : inria-00071876 , version 1
Laurent Lefèvre, E. Lemoine, Cong-Duc Pham, B. Tourancheau. Fast Forwarding with Network Processors. RR-4710, INRIA. 2003. ⟨inria-00071876⟩
80 Consultations
92 Téléchargements
