Statistical model-based damage detection and localization: subspace-based residuals and damage-to-noise sensitivity ratios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Michèle Basseville
Laurent Mevel
The vibration-based structural health monitoring problem is addressed as the double task of detecting damages modeled as changes in the eigenstructure of a linear dynamic system, and localizing the detected damages within (a FEM of) the monitored structure. The proposed damage detection algorithm is based on a residual generated from a stochastic subspace-based covariance driven identification method and on the statistical local approach to the design of detection algorithms. This algorithm basically computes a global test, which performs a sensitivity analysis of the residuals to the damages, relative to uncertainties and noises. How this residual relates to some residuals for damage localization and model updating is discussed. Damage localization is stated as a detection problem. This problem is addressed by plugging aggregated sensitivities of the modes and mode-shapes w.r.t. FEM structural parameters in the above setting. This results in directional tests, which perform the same type of damage-to-noise sensitivity analysis of the residual as for damage detection. How the sensitivity aggregation mechanism relates to sub-structuring is outlined. Numerical results obtained on one example are reported.
RR-4645.pdf (435.97 Ko) Télécharger le fichier
inria-00071940 , version 1 (23-05-2006)
  • HAL Id : inria-00071940 , version 1
Michèle Basseville, Laurent Mevel, Maurice Goursat. Statistical model-based damage detection and localization: subspace-based residuals and damage-to-noise sensitivity ratios. [Research Report] RR-4645, INRIA. 2002. ⟨inria-00071940⟩
225 Consultations
551 Téléchargements
