Randomized Permutations in a Coarse Grained Parallel Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We show how to distribute data at random (not to be confounded with permutation routing) in a coarse grained parallel environment with $p$ processors. Previously known methods were not able to fulfill the three criteria of uniformity, work-optimality and balance among the processors simultaneously. To guarantee the uniformity we investigate the matrix of communication requests between the processors. We show that its distribution is a generalization of the multivariate hypergeometric distribution and give algorithms to compute it efficiently.
Autre [cs.OH]
RR-4639.pdf (255.04 Ko) Télécharger le fichier
inria-00071946 , version 1 (23-05-2006)
  • HAL Id : inria-00071946 , version 1
Jens Gustedt. Randomized Permutations in a Coarse Grained Parallel Environment. [Research Report] RR-4639, INRIA. 2002, pp.12. ⟨inria-00071946⟩
90 Consultations
117 Téléchargements
