Asymptotic analysis of shape functionals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
A family of boundary value problems is considered in domains $\Omega(\varepsilon)=\Omega\setminus\overline\omega_\varepsilon \subset\mathbb{R}^n$, $n\ge 3$, with cavities $\omega_\varepsilon$ depending on a small parameter $\varepsilon\in (0,\varepsilon_0]$. An approximation ${\mathcal U}(\varepsilon, x)$, $x\in\Omega(\varepsilon)$, of the solution $u(\varepsilon, x)$, $x\in\Omega(\varepsilon)$, to the boundary value problem is obtained by an application of the methods of matched and compound asymptotic expansions. The asymptotic expansion is constructed with precise a priori estimates for solutions and remainders in Hölder spaces, i.e., pointwise estimates are established as well. The asymptotic solution ${\mathcal U}(\varepsilon, x)$ is used in order to derive the first term of the asymptotic expansion with respect to $\varepsilon$ for the shape functional ${\mathcal J}(\Xi(\varepsilon))={\mathbb{J}}_\varepsilon(u) \cong{\mathbb{J}}_\varepsilon({\mathcal U})$. In particular, we obtain the {\it topological derivative} $\cT(x)$ of the shape functional $\cJ(\Xi)$ at a point $x\in\O$. Volume and surface functionals are considered in the paper.
Autre [cs.OH]
RR-4633.pdf (649.59 Ko) Télécharger le fichier
inria-00071952 , version 1 (23-05-2006)
  • HAL Id : inria-00071952 , version 1
Serguei Nazarov, Jan Sokolowski. Asymptotic analysis of shape functionals. RR-4633, INRIA. 2002. ⟨inria-00071952⟩
65 Consultations
172 Téléchargements
