Purely Periodic beta-Expansions in the Pisot Non-unit Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Valerie Berthe
It is well-known that real numbers with a purely periodic decimal expansion are the rationals having a denominator coprime with 10. We are interested in beta-expansions with a non-unit Pisot basis. We give a characterization of real numbers having a purely periodic expansion in such a basis. The characterization is given in terms of an explicit self-similar compact subset of non-zero measure in a product of a Euclidean space and p-adic spaces.
RR-4619.pdf (282.6 Ko) Télécharger le fichier
inria-00071966 , version 1 (23-05-2006)
  • HAL Id : inria-00071966 , version 1
Valerie Berthe, Anne Siegel. Purely Periodic beta-Expansions in the Pisot Non-unit Case. [Research Report] RR-4619, INRIA. 2002. ⟨inria-00071966⟩
156 Consultations
197 Téléchargements
