Visual Auto-landing of an Autonomous Aircraft - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
This report is the summary of work done in the CIMAR project of collaboration between IST (Lisboa) and the Icare Project (INRIA Sophia Antipolis) for vision-based control applied to an autonomous aircraft. An unified modeling framework is defined and the vision-based auto-landing of the UAV model is analyzed, based on the classical alternative between position-based and image-based visual control. The controller design is adapted for both approaches and simulations results are presented in order to validate the proposed solutions and allow for a critical evaluation of the two approaches.
RR-4606.pdf (684.68 Ko) Télécharger le fichier
inria-00071979 , version 1 (23-05-2006)
  • HAL Id : inria-00071979 , version 1
Patrick Rives, José Raul Azinheira. Visual Auto-landing of an Autonomous Aircraft. RR-4606, INRIA. 2002. ⟨inria-00071979⟩
178 Consultations
381 Téléchargements
