Scale-Invariance of Support Vector Machines based on the Triangular Kernel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
This report focuses on the scale-invariance and the good performances of Support Vector Machines based on the triangular kernel. After a mathematica- l analysis of the scale-invariance of learning with that kernel, we illustrate its behavior with a simple 2D classification problem and compare its performances to those of a Gaussian kernel on face detection and handwritten character recognition
Autre [cs.OH]
RR-4601.pdf (367.84 Ko) Télécharger le fichier
inria-00071984 , version 1 (23-05-2006)
  • HAL Id : inria-00071984 , version 1
Hichem Sahbi, François Fleuret. Scale-Invariance of Support Vector Machines based on the Triangular Kernel. [Research Report] RR-4601, INRIA. 2002. ⟨inria-00071984⟩
112 Consultations
2129 Téléchargements
