Computing connected dominated sets with multipoint relays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Cédric Adjih
Philippe Jacquet
Laurent Viennot
Multipoint relays offer an optimized way of flooding packets in a radio network. However, this technique requires the last hop knowledge: to decide wether or not a flooding packet is retransmitted, a node needs to know from which node the packet was received. When considering broadcasting at IP level, this information may be difficult to obtain. We thus propose a scheme for computing an optimized connected dominating set from multipoint relays. This set allows to efficiently broadcast packets without the last hop information with performances close to multipoint relay flooding.
Autre [cs.OH]
RR-4597.pdf (197.63 Ko) Télécharger le fichier
inria-00071988 , version 1 (23-05-2006)
  • HAL Id : inria-00071988 , version 1
Cédric Adjih, Philippe Jacquet, Laurent Viennot. Computing connected dominated sets with multipoint relays. [Research Report] RR-4597, INRIA. 2002. ⟨inria-00071988⟩
350 Consultations
466 Téléchargements
