Angle-Analyzer: A Triangle-Quad Mesh Codec - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Pierre Alliez
Mathieu Desbrun
We present Angle-Analyzer, a new single-rate compression algorithm for triangle-quad hybrid meshes. Using a carefully-designed geometry-driven mesh traversal and an efficient encoding of intrinsic mesh properties, Angle-Analyzer produces compression ratios 40 better in connectivity and 20 better in geometry than the leading Touma and Gotsman technique for the same level of geometric distortion. The simplicity and performance of this new technique is demonstrated, and we provide extensive comparative tests to contrast our results with the current state-of-the-art techniques.
RR-4584.pdf (1.02 Mo) Télécharger le fichier
inria-00072001 , version 1 (23-05-2006)
  • HAL Id : inria-00072001 , version 1
Haeyoung Lee, Pierre Alliez, Mathieu Desbrun. Angle-Analyzer: A Triangle-Quad Mesh Codec. RR-4584, INRIA. 2002. ⟨inria-00072001⟩
158 Consultations
409 Téléchargements
