Airy Phenomena and Analytic Combinatorics of Connected Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Bruno Salvy
Gilles Schaeffer
Until now, the enumeration of connected graphs has been dealt with by probabilistic methods, by special combinatorial decompositions or by somewhat indirect formal series manipulations. We show here that it is possible to make analytic sense of the divergent series that expresses the generating function of connected graphs. As a consequence, it becomes possible to derive analytically known enumeration results using only first principles of combinatorial analysis and straight asymptotic analysis---specifically, the saddle-point method. In this perspective, the enumeration of connected graphs by excess (of number of edges over number of vertices) derives from a simple saddle-point analysis. Furthermore, a refined analysis based on coalescent saddle points yields complete asymptotic expansions for the number of graphs of fixed excess, through an explicit connection with Airy functions.
Autre [cs.OH]
RR-4581.pdf (935.7 Ko) Télécharger le fichier
inria-00072004 , version 1 (23-05-2006)
  • HAL Id : inria-00072004 , version 1
Philippe Flajolet, Bruno Salvy, Gilles Schaeffer. Airy Phenomena and Analytic Combinatorics of Connected Graphs. [Research Report] RR-4581, INRIA. 2002. ⟨inria-00072004⟩
62 Consultations
206 Téléchargements
