The Protein Threading Problem is in P? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
This work is about a problem from computational biology known as protein threading problem. By finding out an appropriate linear mixed-integer programming (MIP) formulation we demonstrate that the real-live instances of this problem could be efficiently solved by using only some linear-programming (LP) solver instead of special-purpose branch&bound algorithm. This is due to the fact that within the frame of MIP model proposed, all biological instances, we were able to test, attain their optima at feasible vertices of the underlying LP polytope which is the essence of the statement in the title.
Autre [cs.OH]
RR-4577.pdf (278.31 Ko) Télécharger le fichier
inria-00072011 , version 1 (23-05-2006)
  • HAL Id : inria-00072011 , version 1
Nicola Yanev, Rumen Andonov. The Protein Threading Problem is in P?. [Research Report] RR-4577, INRIA. 2002. ⟨inria-00072011⟩
150 Consultations
106 Téléchargements
