Cascadic multigrid for the advection-diffusion equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
In this report, the Cascadic Multigrid method (CMG), viewed as a «one-way» multigrid method not involving pre-smoothing or restriction steps, is defined and tested in the case of a simple 2D advection-diffusion problem. Jacobi and Gauss-Seidel smoothers are employed. While the Cascadic Multigrid method is very effective for relatively small Reynolds numbers, the convergenc- e rate deteriorates when advection and diffusion approximately balance each other. However, for larger Reynolds numbers, the method improves somewhat and achieves a mesh-independent convergence rate. In the next step, we recommend that the CMG method should be designed and tested for boundary layers in conjunction with adaptive meshes and/or semi-coarsening.
Autre [cs.OH]
RR-4574.pdf (340.86 Ko) Télécharger le fichier
inria-00072014 , version 1 (23-05-2006)
  • HAL Id : inria-00072014 , version 1
Xuejun Xu, Ales Janka, Jean-Antoine Desideri. Cascadic multigrid for the advection-diffusion equation. [Research Report] RR-4574, INRIA. 2002. ⟨inria-00072014⟩
166 Consultations
123 Téléchargements
