Synthesis of Distributed Testers from True-concurrency Models of Reactive Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Automatic synthesis of test cases for conformance testing has been principall- y developed with the objective of generating sequential test cases. In the distributed system context, it is worth extending the synthesis techniques to the generation of multiple testers. We base our work on our experience in using model-checking techniques, as successfully implemented in the TGV tool. Continuing the works of A. Ulrich and H. König, we propose to use a true-concurrency model based on graph unfolding. The article presents the principles of a complete chain of synthesis, starting from the definition of test purposes and ending with a projection onto a set of testers.
Autre [cs.OH]
RR-4567.pdf (367 Ko) Télécharger le fichier
inria-00072021 , version 1 (23-05-2006)
  • HAL Id : inria-00072021 , version 1
Claude Jard. Synthesis of Distributed Testers from True-concurrency Models of Reactive Systems. [Research Report] RR-4567, INRIA. 2002. ⟨inria-00072021⟩
70 Consultations
291 Téléchargements
