s'authentifier
version française rss feed
inria-00072024, version 1
A Greedy Delaunay Based Surface Reconstruction Algorithm
David Cohen-Steiner () 1, Frank Da
N° RR-4564 (2002)
Résumé : In this paper, we present a new greedy algorithm for surface reconstruction from unorganized point sets. Starting from a seed facet, a piecewise linear surface is grown by adding Delaunay triangles one by one. The most plausible triangles are added in the first place, in a way that prevents the appearance of topological singularities. The output is thus guaranteed to be a piecewise linear orientable manifold, possibly with boundary. Experiments show that this method is very fast, and achieves topologically correct reconstruction in most cases. Moreover, it can handle surfaces with complex topology, boundaries, and non uniform sampling.
  • Domaine : Informatique/Autre
  • Mots-clés : DELAUNAY TRIANGULATION / SURFACE RECONSTRUCTION / ADVANCING FRONT METHOD
  • Référence interne : RR-4564
  • inria-00072024, version 1
  • oai:hal.inria.fr:inria-00072024
  • Contributeur :
  • Soumis le : Mardi 23 Mai 2006, 19:35:41
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:26
tous les articles de la base du CCSd...
