Comparing multifractal formalisms : the Neighboring Boxes Condition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Julien Barral
  • Fonction : Auteur
  • PersonId : 921315
  • IdRef : 14587494X
Fathi Ben Nasr
  • Fonction : Auteur
Jacques Peyrière
  • Fonction : Auteur
Physicists usually compute dimensions by using boxes and they also do so when dealing with multifractals. Also in the study of some dynamical systems and multiplicative processes, boxes naturally appear. On the other hand, in geometric measure theory, it is preferred to perform computations which do not depend on a grid. This paper provides a bridge between the boxes and the grid-free approaches to the multifractal analysis of measures. Results for quasi-Bernoulli measures and statistically self-similar measures are obtained.
RR-4562.pdf (327.52 Ko) Télécharger le fichier
inria-00072026 , version 1 (23-05-2006)
  • HAL Id : inria-00072026 , version 1
Julien Barral, Fathi Ben Nasr, Jacques Peyrière. Comparing multifractal formalisms : the Neighboring Boxes Condition. [Research Report] RR-4562, INRIA. 2002. ⟨inria-00072026⟩
102 Consultations
216 Téléchargements
