Optimality of the CUSUM Procedure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Optimality of CUSUM under a Lorden type criterion setting is considered. We demonstrate the optimality of the CUSUM test for Itô processes, in a sense similar to Lorden's, but with a criterion that replaces expected delays by the corresponding Kullback-Leibler divergence.
Autre [cs.OH]
RR-4541.pdf (152.3 Ko) Télécharger le fichier
inria-00072047 , version 1 (23-05-2006)
  • HAL Id : inria-00072047 , version 1
George V. Moustakides. Optimality of the CUSUM Procedure. [Research Report] RR-4541, INRIA. 2002. ⟨inria-00072047⟩
48 Consultations
211 Téléchargements
