On propagation characteristics of resilient functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Enes Pasalic
  • Fonction : Auteur
In this paper we derive several important results towards a better understandi- ng of propagation characteristics of resilient Boolean functions. We first introduce a new upper bound on nonlinearity of a given resilient function depending on the propagation criterion. We later show that a large class of resilient functions admit a linear structure; more generally, we exhibit some divisibility properties concerning the Walsh-spectrum of the derivatives of any resilient function. We prove that, fixing the order of resiliency and the degree of propagation criterion, a high algebraic degree is a necessary condition for construction of functions with good autocorrelati- on properties. We conclude by a study of the main constructions of resilient functions. We notably show how to avoid linear structures when a linear concatenation is used and when the recursive construction introduced in is chosen.
RR-4537.pdf (347.84 Ko) Télécharger le fichier
inria-00072051 , version 1 (23-05-2006)
  • HAL Id : inria-00072051 , version 1
Pascale Charpin, Enes Pasalic. On propagation characteristics of resilient functions. [Research Report] RR-4537, INRIA. 2002. ⟨inria-00072051⟩
71 Consultations
172 Téléchargements
