A vectorial Matching Pursuit algorithm with an application to the analysis of Vecto-cardiogram signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
A modification of the Matching Pursuit algorithm is presented which allows the recovery of a vector-valued signal from partial data (a relaxed version of the algorithm is also introduced, and shown to converge). The new algorithm is illustrated by its application to the analysis of a vecto-cardiogram signal.
RR-4535.pdf (339.76 Ko) Télécharger le fichier
inria-00072053 , version 1 (23-05-2006)
  • HAL Id : inria-00072053 , version 1
Catherine Bonnet, Jonathan R. Partington, Michel Sorine. A vectorial Matching Pursuit algorithm with an application to the analysis of Vecto-cardiogram signals. [Research Report] RR-4535, INRIA. 2002. ⟨inria-00072053⟩
63 Consultations
84 Téléchargements
