Multi-Periodic Process Networks: Technical Report
This paper aims at modeling video stream applications with structured data and multiple clocks. Multi-Periodic Process Networks (MPPN) are real-time process networks with an adaptable degree of synchronous behavior and a hierarchical structure. MPPN help to describe stream-processing applications and deduce resource requirements such as parallel functional units, throughput and buffer sizes.
