Faster Triangle-Triangle Intersection Tests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Olivier Devillers
Philippe Guigue
  • Fonction : Auteur
This paper presents a new method for computing whether or not two triangles in three dimensions intersect. The code is very efficient and requires minimum arithmetic precision. Indeed, all branching decisions are carried out by evaluating the signs of degree three polynomials. In addition, an efficient test is proposed for the two-dimensional case.
Autre [cs.OH]
RR-4488.pdf (175.85 Ko) Télécharger le fichier
inria-00072100 , version 1 (23-05-2006)
  • HAL Id : inria-00072100 , version 1
Olivier Devillers, Philippe Guigue. Faster Triangle-Triangle Intersection Tests. RR-4488, INRIA. 2002. ⟨inria-00072100⟩
1375 Consultations
18385 Téléchargements
