Properties of the subtraction valid for any floating point system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Sylvie Boldo
Marc Daumas
  • Fonction : Auteur
We start in this text with a very generic definition of floating point systems. We show that just a few very natural necessary conditions are sufficient to focus down to two classes of implemented floating point arithmetic. Later, we prove that, for all the existing implementations, high level properties such as Sterbenz's theorem are satisfied. We finish this text by focusing on the differences between an IEEE-754 compatible unit and Texas Instrument TMS/SMJ 320C3x digital signal processing circuit that is recommended for avionics and military applications. The results presented in this text have been validated by the Coq automatic proof checker to build confidence for later implementations in critical systems such as an aircraft flight control primary or secondary computer.
Autre [cs.OH]
RR-4473.pdf (283.92 Ko) Télécharger le fichier
inria-00072115 , version 1 (23-05-2006)
  • HAL Id : inria-00072115 , version 1
Sylvie Boldo, Marc Daumas. Properties of the subtraction valid for any floating point system. 7th International Workshop on Formal Methods for Industrial Critical Systems, 2002, Málaga, Spain. pp.137-149. ⟨inria-00072115⟩
113 Consultations
410 Téléchargements
