Improving Reactivity to I/O Events in Multithreaded Environments Using a Uniform, Scheduler-Centric API - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Reactivity to I/O events is a crucial factor for the performance of modern multithreaded distributed systems. In our scheduler-centric approach, an application detects I/O events by requesting a service from a detection server, through a simple, uniform API. We show that a good choice for this detection server is the thread scheduler. This approach simplifies application programming, significantly improves performance, and provides a much tighter control on reactivity.
RR-4471.pdf (152.82 Ko) Télécharger le fichier
inria-00072117 , version 1 (23-05-2006)
  • HAL Id : inria-00072117 , version 1
Luc Bougé, Vincent Danjean, Raymond Namyst. Improving Reactivity to I/O Events in Multithreaded Environments Using a Uniform, Scheduler-Centric API. [Research Report] RR-4471, INRIA. 2002. ⟨inria-00072117⟩
210 Consultations
246 Téléchargements
