Diagnosis of Asynchronous Discrete Event Systems, a Net Unfolding Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Albert Benveniste
Eric Fabre
In this paper we formulate asynchronous diagnosis by means of hidden state history reconstruction, from alarm observations. We follow a so-called true concurrency approach, in which no global state and no global time is available. Instead, we use only local states in combination with a partial order model of time, in which local events are ordered if they are either generated on the same site, or related via some causality relation. Our basic mathematical tool is that of net unfoldings originating from the research area. This study was motivated by the problem of event correlation in telecommunications network management.
RR-4461.pdf (608.92 Ko) Télécharger le fichier
inria-00072127 , version 1 (23-05-2006)
  • HAL Id : inria-00072127 , version 1
Albert Benveniste, Eric Fabre, Claude Jard, Stefan Haar. Diagnosis of Asynchronous Discrete Event Systems, a Net Unfolding Approach. [Research Report] RR-4461, INRIA. 2002. ⟨inria-00072127⟩
168 Consultations
244 Téléchargements
