Image Matching with Scale Adjustment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
In this report we address the problem of matching two images with two different resolutions: a high-resolution image and a low-resolution one. The difference in resolution between the two images is not known and without loss of generality one of the images is assumed to be the high-resolution one. On the premise that changes in resolution act as a smoothing equivalent to changes in scale, a scale-space representation of the high-resolution image is produced. Hence the one-to-one classical image matching paradigm becomes one-to-many because the low-resolution image is compared with all the scale-space representations of the high-resolution one. Key to the success of such a process is the proper representation of the features to be matched in scale-space. We show how to represent and extract interest points at variable scales and we devise a method allowing the comparison of two images at two different resolutions. The method comprises the use of photometr- ic- and rotation-invariant descriptors, a geometric model mapping the high-resolution image onto a low-resolution image region, and an image matching strategy based on local constraints and on the robust estimation of this geometric model. Extensive experiments show that our matching method can be used for scale changes up to a factor of 6.
Autre [cs.OH]
RR-4458.pdf (5.68 Mo) Télécharger le fichier
Format : Figure, Image
inria-00072130 , version 1 (23-05-2006)
  • HAL Id : inria-00072130 , version 1
Yves Dufournaud, Cordelia Schmid, Radu Horaud. Image Matching with Scale Adjustment. [Research Report] RR-4458, INRIA. 2002. ⟨inria-00072130⟩
152 Consultations
319 Téléchargements
