Reflected BSDE's , PDE's and Variational Inequalities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Vlad Bally
  • Fonction : Auteur
M.E. Caballero
  • Fonction : Auteur
B. Fernandez
  • Fonction : Auteur
Nicole El Karoui
  • Fonction : Auteur
We discuss a class of semilinear PDE's with obstacle, of the form (_t+L)u+f(t,- x,u,^*u)+=0,uh,u_T=g where h is the obstacle. The solution of such an equation (in variational sense) is a couple (u,) where uL^2([0,T];H^1) and is a positive Radon measure concentrated on u=h. We prove that this equation has a unique solution and u is the maximal solution of the correspond- ing variational inequality. The probabilistic interpretation (Feynman-Kac formula) is given by means of Reflected Backward Stochastic Differential Equations. We give a new construction of solutions of such equations using a maximum principle. This perimts to consider obstacles with jumps.
RR-4455.pdf (339.18 Ko) Télécharger le fichier
inria-00072133 , version 1 (23-05-2006)
  • HAL Id : inria-00072133 , version 1
Vlad Bally, M.E. Caballero, B. Fernandez, Nicole El Karoui. Reflected BSDE's , PDE's and Variational Inequalities. [Research Report] RR-4455, INRIA. 2002. ⟨inria-00072133⟩
323 Consultations
691 Téléchargements
