s'authentifier
version française rss feed
inria-00072135, version 1
A Linear Bound on the Complexity of the Delaunay triangulation of points on polyhedral surfaces
Dominique Attali 1, Jean-Daniel Boissonnat ()
N° RR-4453 (2002)
Résumé : Delaunay triangulations and Voronoi diagrams have found numerous applications in surface modeling, surface mesh generation, deformable surface modeling and surface reconstruction. Many algorithms in these applications begin by constructing the three-dimensional Delaunay triangulation of a finite set of points scattered over a surface. Their running-time therefore depends on the complexity of the Delaunay triangulation of such point sets. Although the Delaunay triangulation of points in ^3 can be quadratic in the worst-case, we show that, under some mild sampling condition, the complexity of the 3D Delaunay triangulation of points distributed on a fixed number of facets of ^3 (e.g. the facets of a polyhedron) is linear. Our bound is deterministic and the constants are explicitly given.
  • Domaine : Informatique/Autre
  • Mots-clés : COMPUTATIONAL GEOMETRY / DELAUNAY TRIANGULATION / VORONOI DIAGRAM / POLYHEDRAL SURFACES / COMPLEXITY / SURFACE SAMPLING / SURFACE MODELING / SURFACE RECONSTRUCTION
  • Référence interne : RR-4453
  • inria-00072135, version 1
  • oai:hal.inria.fr:inria-00072135
  • Contributeur :
  • Soumis le : Mardi 23 Mai 2006, 19:53:03
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:26
tous les articles de la base du CCSd...
