A Direct Study in a Hilbert-Schmidt Framework of the Riccati Equation Appearing in a Factorization Method of Second Order Elliptic Boundary Value Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
In this report we come back to the method of factorization of a second order elliptic boundary value problem presented in . In this paper, it was shown that, in the case of a cylinder, the boundary value problem can be factorized in two uncoupled first order initial value problems. This factorization utilizes the Dirichlet to Neumann operator which satisfies a Riccati equation. Here we consider Hilbert-Schmidt operators, a framework already used by R. Temam which provides tools for a direct study of this Riccati equation.
RR-4451.pdf (498.12 Ko) Télécharger le fichier
inria-00072137 , version 1 (23-05-2006)
  • HAL Id : inria-00072137 , version 1
Jacques Henry, Angel M. Ramos. A Direct Study in a Hilbert-Schmidt Framework of the Riccati Equation Appearing in a Factorization Method of Second Order Elliptic Boundary Value Problems. [Research Report] RR-4451, INRIA. 2002. ⟨inria-00072137⟩
74 Consultations
168 Téléchargements
