Reduced Load Equivalence under Subexponentiality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
The stationary workload W^_A+B of a queue with capacity loaded by two independent processes A and B is investigated. When the probability of load deviation in process A decays slower than both in B and e^-, we show that W^_A+B is asymptotically equal to the reduced load queue W^-b_A, where b is the mean rate of B. This complements the known result that this property does not hold when both processes have lighter than e^- deviation decay rates. Furthermore, using the same methodology, we show that under an equivalent set of conditions the results on sampling at subexponential times hold.
RR-4444.pdf (292.04 Ko) Télécharger le fichier
inria-00072144 , version 1 (23-05-2006)
  • HAL Id : inria-00072144 , version 1
Predrag Jelenkovic, Petar Momcilovic, Albertus P. Zwart. Reduced Load Equivalence under Subexponentiality. [Research Report] RR-4444, INRIA. 2002. ⟨inria-00072144⟩
36 Consultations
201 Téléchargements
