inria-00072148, version 1
Forwarders vs. Centralized Server : An Evaluation of two Approaches for Locating Mobile Agents
Sara Alouf
1Fabrice Huet
2Philippe Nain
N° RR-4440 (2002)
Résumé : This paper evaluates and compares the performance of two approaches for locating an agent (e.g. a code) in a mobile agent environment. The first approach dynamically creates a chain of forwarders to locate a moving agent whereas the second one relies on a centralized server to perform this task. Based on a Markov chain analysis, we compute the performance of each scheme (time to reach an agent, number of forwarders) and compare them first with simulations and second with experimental results obtained by using ProActive, a Java library. Depending on the system parameters we identify the best scheme and observe that within a LAN the server yields the best performan- ce whereas the forwarders yield the best performance within a MAN.
- 1 : MISTRAL (INRIA Sophia Antipolis)
- INRIA
- 2 : OASIS (INRIA Sophia Antipolis / Laboratoire I3S)
- INRIA – Université de Nice Sophia Antipolis (UNS) – CNRS : UMR7271
- Domaine : Informatique/Autre
- Mots-clés : MOBILE CODE / MIGRATION / CENTRALIZED SERVER / FORWARDERS / MARKOV CHAIN
- Référence interne : RR-4440
- inria-00072148, version 1
- http://hal.inria.fr/inria-00072148
- oai:hal.inria.fr:inria-00072148
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mardi 23 Mai 2006, 19:54:34
- Dernière modification le : Mercredi 31 Mai 2006, 14:24:26
Documents associés
Exporter
