Fault isolation for diagnosis: nuisance rejection and multiple hypotheses testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Fault detection, fault isolation and fault diagnosis are addressed within a statistical framework. The corresponding inference problems are stated. Several statistical tools for solving these inference problems are described. Particular emphasis is put on dealing with nuisance parameters and deciding between multiple hypotheses. How to use these tools for solving problems is discussed. An example illustrates some of the proposed methods.
RR-4438.pdf (229.06 Ko) Télécharger le fichier
inria-00072150 , version 1 (23-05-2006)
  • HAL Id : inria-00072150 , version 1
Michèle Basseville, Igor V. Nikiforov. Fault isolation for diagnosis: nuisance rejection and multiple hypotheses testing. [Research Report] RR-4438, INRIA. 2002. ⟨inria-00072150⟩
241 Consultations
518 Téléchargements
